Toshiba TE50T11 - turns off and power light blinks
Old 05-19-08, 09:35 PM
Hi, I've got a problem with my Toshiba TheaterView TV. It started a few months ago where the TV would just turn off and the power indicator light would just blink. The problem is really random - happens every 5 minutes or will go hours or days before it happens. When it happens, we unplug it and plug it back in and then it works fine until the next time it just happens to decide to turn off.
I'm assuming it is power supply or board related. I took off the back cover and noticed it was very dirty - did some spring cleaning and worked for a little bit, but then started again. I've read a few posts on this, but didn't really see a solution.
Couple of questions:
1. What would be a ballpark figure for repair if going to a service center? Trying to determine if it makes sense to just buy a new TV!
2. Anyone know how to get a service manual on the TV? I tried a service manual website and could not find it listed.
3. Would anyone know of a good service center in the sacramento/surrounding area? Toshiba service site shows someone in the bay area.
thanks for your help.
dave
Old 06-22-08, 08:27 AM
Smile Same Problem HELP!!
Hi Dave...just read your post and we are having the samer exact problems with our same model TV. Have you had any luck resolving your issues? If so, could you please pass on any info you have about repair or tips?? Thanks so much.
Old 08-25-08, 08:50 PM
Toshiba blinking power light
Did anyone find a solution to this? Mine is now doing the same thing. Power light blinks and shuts down the tv...power light continues to blink.
Old 08-25-08, 10:19 PM
No solution found or provided. My only solution was to purchase a 67 inch HD TV and put mine to the TV graveyard
Old 08-26-08, 06:15 AM
It's most likely the voltage regultor ic.It is a common failure of this set.
