Fender Amp problem
Old 05-22-08, 06:42 AM
Fender Amp problem
I have a Fender Stage 185 amp that makes a cracking sound when played. I tried the speaker in another amp and that is fine and the guitar and cords work fine with another amp. With the volume barely on it doesn't crack but once it gets even up to 1 the sound cracks. I've tried adjusting the gains and input levels but that doesn't help.
Old 05-22-08, 08:21 AM
G
One possibility would be a bad connection
someplace, maybe on a circuit board itself.
Many times they mount input and output
jacks directly to a circuit board. Sometimes
the solder joints can get bad causing it to make
noise. Another possibility is that you have a dirty
control.
