Optoma RD65 Rear Proector TV
Received 0 Votes
I'm trying to get a copy of the service manual but Optoma doesn't seem to sell this one. Not sure why but I need a copy to troubleshoot; dead power supply. I was given this set and I do know that this model has had some issues. It as manufactured in Nov 2004. Any assistance would be appreciated.
Thanks,
Thanks,
Received 0 Votes
I couldn't find any place to get a service manual for it.When I can't get one , there is an IC to SAMS cross reference available on the Sams Photo Fact home page.You can look up the IC's in the circuit and find out if another set is using the same one.If it comes up with a match then the circuit the IC is used in will be close enough to the one in the sams manuel to give you some place to start.At the very least , you will know what each pin on the IC is used for.
Received 0 Votes
I'll give it a try,
thank you,
thank you,
Previous Thread
Next Thread
