RCA Projection TV
Received 0 Votes
RCA Projection TV
I started out replacing a fuse, It was so dirty that iI cleaned everything. Now my picture appears misaligned. The green, red and blue are not in sync. For example the channel number will have all three colors around the number, so it looks like three numbers in different colors. How should I correct this problem? How do I realign? I should have left it dirty!!!
Thank You
Bill
Thank You
Bill
Received 0 Votes
Was the set playing ok,then power went out and wouldn't come back on?Then you took the back off and found a blown fuse.Replaced it and now it comes on but the picture is messed up.
If this is the case,then you have a bad convergence power supply board.Post the model # and I'll find the part #'s and post back.You will notice that you no longer have the option to adjust convergence in your menu.
Please don't adjust anything inside the set!This is a common problem and you didn't cause it by dusting out the set.
Previous Thread
Next Thread
