Help!!!!!
Old 09-13-08, 09:36 AM
Help!!!!!
I have a 27” Sony Trinitron TV, that I brought new in the mid to late 90's. The last few months it’s been acting up on me. When I turn it on, the picture comes on great for a few seconds and then the whole picture moves to the right hand side of the screen and the left hand side turns black and then the whole screen goes black. Everyone I have talk to say to buy a new TV, but right now I cannot afford a new one. I am thinking it is a vertical hold. I am an electrician and would like to fix this myself. If somebody out there knows what this is and tells me how to or what to do to fix this. The model # is KV 35V65 built in Dec. 1998 and ser. # is 9020506
Old 09-13-08, 10:00 AM
HotxxxxxxxOKC's Avatar
Hi!
Could you please most the model # of the set? If you're patient, Craftsman50 knows televisions pretty good, so hang it there.
Old 09-13-08, 10:48 AM
Originally Posted by HotinOKC View Post
Hi!
model # is KV 35V65, ser. # is 9020506 and built in 1998
Old 09-13-08, 12:22 PM
I found this bulliten for your sony.
Subject
Intermittent half of screen pulled in, Tuner
Symptoms / Customer Description
Picture will go into blanking with top half of screen pulled in. White with retrace lines bottom half is darker with noise. Picture also will pull in on the sides.
[Primary Symptom Code: 1327 ]
Solution
Found tuner/Pin 5 (Sub Data) was shorted.
Replaced tuner.
This tuner supplied by Mr.JD last month has IC102 damage. (Mitsubishi IC) This is problem we discovered from market defect sample returns This part was redesigned for better EOS protection and from July '99 Plant started using new improved part.
Model Details
Model Serial Start Serial End Factory Mfg Date Family Name Family Type Category
KV32S40 ALL ALL STE 5/1/1998 AA2D 40 TV and Display (TVP)
KV32S45 ALL ALL STE 5/1/1998 AA2D 40 TV and Display (TVP)
KV32V40 ALL ALL STE 5/1/1998 AA2D 40 TV and Display (TVP)
KV35S40 ALL ALL PITT 5/1/1998 AA2D 40 TV and Display (TVP)
KV35S45 ALL ALL STE 5/1/1998 AA2D 40 TV and Display (TVP)
KV35V65 9007021 9007021 PITT 5/1/1998 AA2D 40 TV and Display (TVP)
Associated Parts
Part Number Reference Number Description Symptom Code Section Code PCB Reference Defect Code Repair Code
859843000 TU102 TUNER BTF-FA401 1327 TUN A A A
Check to see if your tv has this pin shorted on the tuner.If unsure,you can unsolder and remove tuner ,then use A/V jacks to check to see if set operates ok with with tuner removed.
Post back and let me know results.
