RCA 32" TV (blows horizontal output)
Old 09-14-08, 01:11 PM
G
I am working with an RCA model 32F530T TV.
The chassis number is ATC113-CD4.
The unit makes a constant chirp noise when plugged in.
I checked it out and found that the horizontal output
transistor was shorted, its a 2SC5148 with no internal
damper diode. I checked the surrounding components
and solder joints all appear to check ok. I replaced the
transistor but when I plugged the unit in it popped the
transistor and started chirping again. I'm thinking
that the flyback may be at the source of the problem.
However I have seen so many replace it in cases like
this just to find that it really wasnt problem and I dont
want to be among them. (Any help would be apreciate)
Something I noticed when replacing the HOT is that they didnt
use any heat sink compound on the transistor surface.
Is there any reason why I shouldnt use any?
Old 09-14-08, 02:11 PM
C
The flyback transformer is the # 1 problem with this model set.Don't need heat sink paste on hot,does not run hot in this set.
Old 09-15-08, 04:05 PM
G
Thanks for the reply,
I'll see about getting a flyback.
Do you have any experience with ASTI or HR Diemen brand
replacement flybacks? Are they ok or no good?
Old 09-15-08, 04:44 PM
C
I used to use Asti,they are good.Never bought from the other guys.
Old 09-27-08, 06:51 PM
G
A new flyback and HOT got it running.
Thanks
