Sony projection color convergence
Old 10-30-08, 01:49 PM
I've got a Sony projection TV KP-43T75, does anyone have a service manual or know how to get into the service menu..I know its done through the remote but can't remember the procedure..thanks in advance.
Old 10-30-08, 05:45 PM
There is nothing in the service menu you need to adjust.If your convergence is off and you can't adjust it from the user menu then the set has a problem that will need to be fixed.
Old 10-30-08, 06:02 PM
green
Then what would you recommend to get rid of the green hue around the pic..
Old 10-30-08, 06:11 PM
The set is 8 years old.When is the last time you took the back off and cleaned the mirror and top of the crt lenses?
Old 10-30-08, 06:35 PM
Never ..thanks will give it try..let you know.
Old 11-02-08, 05:46 PM
You can get into Service Mode on most Sony TV's as follows: TV must be off. Using remote, press Display, 5, VOL UP, Power. A common convergence problem on this set is the STK chip. There are two chips marked STK-392-150. Good luck.
