jvc av-27bx4
Old 11-03-08, 07:43 PM
O
jvc av-27bx4
hi, i have an older jvc tv that has been working good for a long time, but reciently when i turn it on all i get is a white line across the center of the screen... the sound is fine but i cannot get the picture to work normally... i was wondering if i could repair it or if it was better to just get a new one... thanks!
mark
Old 11-04-08, 03:24 AM
C
If you have good soldering skills it's an easy fix.The vertical output ic is bad and mayby a cap or 2.Did it have distortion at the top of the picture for awhile before it went out?
Old 11-04-08, 03:24 PM
O
no... i dont remember any distortion... but i may have not noticed it... and do you know where i can get info on how to fix this? i can solder pretty good but i have no idea where the vertical output ic is... lol
thanks alot for the help by the way
mark
Old 11-04-08, 06:08 PM
C
The part # is LA7837 .It will be mounted on a heat sink.Has 13 legs and is about 1 inch long and 1/8 inch thick.You can google it and find a place to get it and maybe a pic of what it looks like.
Old 11-13-08, 07:15 PM
I have a Sanyo TV with the same problem. But mine DID have distortion at the top of the picture for a long time. A bunch of horizontal lines appeared on the top two inches of the screen. Why did you ask if there was distortion - does that point to something specific?
Old 11-14-08, 03:42 AM
C
The distortion is cause by a cap going bad.I you replace the cap soon you won't have to replace the ic.The bad cap if not replacd will cause the ic to fail.
Old 11-14-08, 09:31 AM
Thanks for the response. When the vertical collapse first started, I could hit the side of the TV and it would correct itself. But now even that does not work anymore. I resoldered the IC with no luck, so I am going to try to replace it. How would I determine which caps may need to be replaced as well?
Old 11-14-08, 04:09 PM
C
There are usually only about 3 electrolitic caps located close by the ic.Since you may have to order the part may as well replace them too,they are cheap.
