Prima TV no Video
Old 11-07-08, 11:50 AM
Prima TV no Video
Prima Q2716, 2003. Blue raster with faint shadows. This is the same if you use the AV jacks. Sound is OK.
Old 11-07-08, 09:22 PM
This is not going to be a DIY repair.It's best to use a scope to find this type problem.Try to find a shop that will give you a free or cheap estimate for repair to find out if it's worth fixing.
Old 11-07-08, 09:34 PM
I understand what you are saying about the need for a scope, but can you please give me an idea where to look, or at least what the nature of the problem is. it is my guess that It could be a bad capacitor in the vertical cct. Am I on the correct path.
Old 11-07-08, 10:01 PM
You going to need to check the voltages on the crt board on the neck of the crt.There should be a 200 volt line going into the board.On the crt socket pins on the board the R,G,& B guns should have about 150 volts.A scope would tell if there was any video present .It could be a bad crt,or a video problem overdriving the blue gun, or a missing power supply voltage.
Old 11-07-08, 11:17 PM
I'm not sure if I described it properly. The blue raster looks as though you turn a set on without a signal. When you inject a signal cable/AV jack you get a ghosting which indicates weak video. I dont know if this info makes a difference, if it does respond and if not thanks.
Old 11-08-08, 05:20 AM
Thats why you realy need a scope to check to see if the video going up to the crt board is good or bad.If the video is good then its going to be a bad crt or there is a power supply voltage missing to run the video properly.If the video is bad going to the board then a scope is a must to find where the video problem is coming from.
Old 11-10-08, 03:50 PM
The estimate for the Prima was $150, at this point, I would be throwing it out unless you can help me savage it.
Is this part number an AUDIO or VIDEO IC?>>> AN7582
Here are the picture of the T.V screen and the boards.
DSC01141.jpg - Image - Photobucket - Video and Image Hosting
DSC01144.jpg - Image - Photobucket - Video and Image Hosting
DSC01146.jpg - Image - Photobucket - Video and Image Hosting
There is no video now ,even ghosting.
Any help will be appreciated.
Old 11-10-08, 06:07 PM
Ok, since your able to see the menu ok the the crt is ok as well as all the parts on the board on the crt.That means there is a problem with the video coming in to the video processor ic.
The an7582 is an audio output ic.<not the problem>The video processor ic part # is blocked in the picture . It is the biggest ic on the board.Post the # off of it and maybe we can get some info for it.
Old 11-10-08, 07:13 PM
What is the LA78041?
This is one of the Ic's
Old 11-10-08, 08:06 PM
It's a vertical output ic.< not the problem >
Old 11-10-08, 08:30 PM
The ic number is :
XOCECO-B60L2
8809CSBNG4FH2
