Westinghouse 26" flatscreen TV noise
Old 03-15-09, 07:11 AM
I am getting a background/humming noise through my speaker. It will go away when volume is to 0. I have a DVR box connected with HDMI cable. On other sets it seems you could correct this by using volume control on TV to 0 and then raising volume with cable box volume if that makes sense. Anyway, whether I use cable remote or TV remote I get the same volume box on the screen. Is there another way to trouble shoot this noise?
Thanks
Old 03-15-09, 08:11 AM
You didn't mention if you're using the TV's speakers or a separate audio receiver and speakers.
Either way, troubleshooting is a process of elimination.
Can you connect the cable box directly to the TV, bypassing the DVR? This will tell you if the DVR is causing the problem. If the hum is still there, the DVR isn't the culprit.
Disconnect the cable box. Connect a DVD player or VCR to the TV's video and audio RCA inputs and select that input with the TV's remote. If the hum is still there the TV is suspect.
If not, connect those RCA cables to the cable box. If the hum comes back, it's the cable box.
Old 03-15-09, 08:15 AM
It is the TV speaker, nothing external. There is no DVD, player just the cable box, which is a DVR box.
Old 03-16-09, 05:59 AM
Disconnected HDMI cable from TV and then no noise. Once I connected HDMI cable or a direct coax cable bypassing cable box, the noise returns
