recording HD TV signal?
Old 03-28-09, 09:55 AM
W
Just tried recoding the new HD TV signal on my old VHS recorder. Seems to have not worked. On playback all I got was a message on the TV "no video signal". Will I have to be a new VHS recorder? Thanks
Old 03-28-09, 10:14 AM
T
You will need a new recorder - a DVR -
Google "recording HDTV" for a better explaination, but the VHS wont even pick up the signal.
Old 03-28-09, 10:18 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
walker..are you feeding a signal from a digital converter or straight from the antenna? Your VCR does not have a digital tuner..so it won't decode the signal from the antenna. You'd need the converter box to do that for you.
Old 03-28-09, 12:40 PM
W
HDTV VHS recording
thanks I was getting the signal from a HD box form the cable company
Old 03-30-09, 08:30 PM
fewalt's Avatar
If the cable box has an rf coax output, the vcr should be able to record the downconverted SD picture.
fred
