Rolling
Old 04-12-09, 10:25 AM
Rolling
I have a Mitsubishi Tv Model VS-4507R , The picture rolls from bottom to top.
any help would be appreciated
Thanks for your time.
wb
Old 04-12-09, 09:12 PM
This set is about 16 years old?If thats correct the problem is surface mounted caps.You will need good soldering skills to do the repair.
Old 04-13-09, 06:25 AM
The caps are not surface mounts they are barrel type, There are 2 (two) pots
Located near the V-IC v lin and v- hight 2 barrel type caps and several others
Caps of different shapes, sometimes the picture shakes and then rolls, every thing
Other than this works great.
Again thanks for your help
wb
Old 04-13-09, 08:02 AM
You didn't answer the question about soldering.By the way the problem is really common and is NOT in the vertical section.
Old 04-13-09, 08:28 AM
Years ago I repaired electronic monitors and typewriters, I believe I still have
Very good soldering skills.
Thanks again for your time and help.
wb
Old 04-13-09, 09:08 PM
Post some pics of the signal circuit board.The problem is the comb filter module.You can find the right cap by removing the shield and using a hair dryer and canned air.
Old 06-07-09, 01:30 PM
sorry, I had to go out of town on Emergancy.
Craftsman_50 said to Post some pics of the signal circuit board,
How do I do this? Which PCB is the signal board?
Thanks again for your help.
wb
Old 07-17-09, 07:24 PM
