Daewoo DV-500 & Crown CDV771 DVD Players
hello everyone, i am new to this forum and i am looking to enhance my knowledge in several areas of this forum. I have two faulty dvd players and i was wondering if they could be fixed, so here goes:
The first is a Daewoo DV-500 DVD Player:
Problems:
No display, No buttons respond
Analysis:
Removed casing
Checked fuse on pcb and plug fuse and both seem ok.
Green standby light stays on constantly.
I can see the white disk on top of the laser unit spin for roughly 30 seconds when the player is first plugged in.
All cables are correctly inserted into appropriate circuit boards.
The second on is a Crown CDV771 DVD Player:
Problems:
No power
Analysis:
Removed casing and checked fuse on the plug and pcb. There are also signs of rust on the inside - possible water damage?
I know you guys would know a lot more than me about this kind of thing! So i'll leave it to the pro's!!!
Thanks in advance
Problems:
Analysis:
Removed casing
Problems:
No power
Analysis:
Thanks in advance
Talking hypothetically; if could get another unit (which may be possible) surely the repair(s) could be carried out?
However, i wouldn't know where to start?!
For example if the pcb is damaged and i had a replacement i could fix it up right?
Thanks for your input so far
mallett
mallett
sorry i didnt quite explain myself properly! what i mean't to say is if i have one with a faulty drive and the other has a faulty pcb i could get the drive or pcb out the other one to fix one unit?
