6-CD Changer in Auto
I cannot remove the magazine from the changer. The eject button sounds like it's working, but the magazine does not pop up, and I can't manually remove it. Also, I get a "NO CD" message on the display.
You've broken a gear in the CD, ddorando. I suspect you "force loaded" the cartridge. It is a common failure but the unit has to come out of the vehicle to repair it. The only way in is to take the top off the unit, rotate the mechanism manually, and then it will eject. After that, you need to replace the gear.
Smokey
Smokey
