Mounting an LCD TV
Received 0 Votes
Mounting an LCD TV
I am going to wall mount an LCD TV in my bedroom and was wondering about hiding the cables to the TV what steps should I take running inside the wall between the studs, One HDMI,one power from the TV and one cable coax? Thanks
Received 0 Votes
The power is going to have to be an installed outlet, if theres an outlet below where the TV is going, then you can just tap off of that outlet. Now to the TV wiring. what are you planning on hooking up to the TV. Are all your components going to be going through a reciever? You should use HDMI for your cable, and HDMI for a Bluray or upconvert DVD player. you really have no need for a cable coax wire.
