Installing Omnidirectional FM Antenna
Old 08-17-10, 09:03 AM
norb's Avatar
Question Installing Omnidirectional FM Antenna
Hello All,
I was looking to install an fm antenna on top of a hill behind my house. The distance away from my house is about 50ft and the antenna will be at least 10ft off the ground. A few basic questions seeing how I've never done this before. First of all is this application doable? Also if I can do this is the cable used to bring the fm signal from the antenna to the receiver rg6 coax or standard antenna wire? Does anyone have any recommendations as far as an antenna and/or optional or reqired equipment (not really looking for HD but will take it)? Any information will be greatly appreciated and thank you in advance.
Beer 4U2
Old 08-17-10, 12:35 PM
Received 2 Votes on 2 Posts
Yes, it is doable. Google omnidirectional fm antennas. Winegard is a good brand. You will lose some of the signal in the coax but using a low loss coax should work. You mention HD. Are you referring to HD TV?
FM broadcasts at roughly 88 - 108 Mhz while most (not all) HD TV is up in the 300 Mhz range.
Old 08-17-10, 07:34 PM
norb's Avatar
No, dont need the TV signal, only FM. Besides the antenna, mounting equipment and coax is there any other equipment I will need or do I just connect the coax from the antenna to the radio reciever?
Old 08-18-10, 04:10 AM
You might consider a marine antenna. The 8-footers are high gain and omni. Shakespeare website.
Just make sure all of the connections are watertight.
Old 08-18-10, 01:08 PM
Adding a lightning arrester may be a good idea.
Old 08-19-10, 09:09 PM
norb's Avatar
What is the difference between a marine antenna and an omnidirectional antenna?
Old 08-19-10, 10:23 PM
The vertical marine antenna Rick suggested is omnidirectional. It is designed for exposure to harsh weather and may be a good choice for your application.
Old 08-20-10, 06:24 AM
norb's Avatar
A Winegard vertical marine antenna with a lightning arrester it is...
Thank you very much guys
Old 08-21-10, 05:06 AM
A lightning arrestor isn't generally used on marine antennas. They are fiberglass and non-conductive. In fact, I'm wondering if it will affect the performance. Unlike car antennas that use the metal from the car as a ground plane, a marine antenna is self-contained.
If you're mounting it atop a metal tower or mast, make sure the mast is grounded.
Old 08-22-10, 06:46 AM
norb's Avatar
Great....I will be mounting it on a metal tower....By any chance does anyone know how deep a rod should be in the ground to create a good ground? Also does anyone have a model # of a good Winegard vertical FM marine antenna?
Old 08-23-10, 04:20 AM
I don't know if Winegard makes one. I do know that Shakespeare is ubiquitous. I have two of the 8-footers on my boat. The antenna is about $35 and the mount is another $30.
