sony bravia sound goes on and off
Old 09-30-10, 09:43 PM
My 32" sony bravia sound turns off intermittingly. Every 5 minutes it turns off then it comes back on anywhere from a few seconds to a few minutes. the wires seem tight. i will swap wires and possibly get a new cable box. the dvd player works fine. any ideas?
Old 10-01-10, 10:50 AM
if the picture and audio from the dvd player are fine, can you run a test where you connect the cable box to the same audio input that the dvd player is using? do you have another cable box in the house you can swap out to see if the problem is with the cbl bx? what is your connection from the cbl bx to the tv - HDMI, component, composite, coax? have you tried (do you have available) an alternative input on the TV, ie - you're using coax now have you tried component?
Old 10-18-10, 06:27 AM
thanks for the feedback. I added an rca wire or component wire for audio in addition to the hdmi cable and made sure all wires were fully connected. It is working fine now. thanks again.
