trying to get my ge tv on the right channel for satellite
Old 01-23-11, 02:55 PM
B
I am using a universal remote that is controlling the tv, but i can't get it to 00 or get the imput to work.
Old 01-23-11, 06:10 PM
B
connecting an older tv to dish network
I can't get the tv input to work or get to channel 00.
Old 01-23-11, 07:04 PM
fewalt's Avatar
If you have the original tv remote, find the input, tv/video button.
That's if you have connected dish rcvr to tv via composite video cables (yellow, red,white).
or try the menu and scan for channels TV may have menu button on panel..
if that fails you may have to use coax between the two and then simply use
channel 3.
fred
Old 01-23-11, 07:34 PM
B
I don't have the original remote, but can access the menu by the front panel and the universal remote. I still can't get the imput to work. I have tried the cables and the coax together and by themselves and for some reason it still won't work. The ge people told me I would have to get to 00 for the imput. Any ideas?
Old 01-23-11, 08:20 PM
fewalt's Avatar
Ch 00 would only be used for av cables, yel, red, white
remove them, try coax only, then try ch 3 or 4
you should get the dish picture.
fred
Old 01-24-11, 03:49 AM
R
Received 1 Vote on 1 Post
What's the make & model of the TV?
Try going to Channel 2 and then hit the channel down button.
Old 01-24-11, 02:06 PM
B
I have tried that. It still is connecting with the satellite. Any ideas why it won't
Old 01-24-11, 02:12 PM
B
the tv is a ge model #27GT612. it won't go to channel 2. It wants to be at 27 through 50. if i go down from 27 it goes to 99
Old 01-24-11, 04:44 PM
C
Hook up the sat reciever and do a channel search. Only the active channels should show up when you hit channel up or down.If it still does not see the sat , then the tuner has gone bad.It was a common problem in these older sets to loose the lower channels.
Old 01-25-11, 10:05 AM
B
Could the tuner still be bad if I can use the remote to get to the lower channels? Do you know if it is expensive to fix a tuner? I'm guessing it's cheaper than trying to fix the 3 year old HD i'm using the ge to replace.
Old 01-25-11, 11:01 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Sounds like it maybe set to cable. Try setting to broadcast in Menu.
If you do a Google you will find companies the provide replacement remotes specific to your TV perhaps cheaper then GE. Could be the tuner though. Kind of sounds like it.
Old 01-25-11, 08:58 PM
R
Can you get to the lower channels by using the number buttons?
Old 01-26-11, 04:59 AM
C
If you can get the lower channels,do they come in ok or are they scrambled lookung?
Old 01-26-11, 05:12 PM
B
i can get to the lower channels with the remote, but it looks like snow. Just like all the other channels
Old 01-27-11, 11:25 AM
B
I now tried the older set in my bedroom with the coax for tv2 on channel 60 and it works. What does this mean? Could the coax in the living room be bad?
Old 01-27-11, 04:17 PM
C
Do you have a vcr that can play a tape out to channel 3 or 4 ?
Old 01-28-11, 08:12 AM
B
all i have is a blue ray dvd player so I don't think I can hook it up to the older set.
Old 01-28-11, 03:36 PM
C
I would just use the tv in the bedroom where it works.Put the bedroom tv in the living room until you get a new set.
Old 02-12-11, 08:28 PM
A
Received 2 Votes on 2 Posts
Can you use another input instead of the coax? For the other TV try:
Channel 90: S-Video
Channel 91: Video 1
Channel 92: Video 2
