ready to buy another tv
Old 03-28-11, 06:57 PM
I already have a 3yr old Sony Bravia 42" LCD TV that has two RF Connectors. I have an antenna connected to one for over the air and the other one connected to cable.
Now I am looking at another TV to put in our basement family room. I would like to have the antenna hooked up and also the cable but I do not find any TV's that have 2 RF Connectors like our present one. The person at Best Buy said I would need to use a switch which isn't as convenient as our present set up.
Am I missing something or is the only way it can be done today?
Thanks,
Harlan.
Old 03-28-11, 07:38 PM
fewalt's Avatar
Get an RF modulator: cable in, composite out (yellow, red, white out to TV)
fred
Old 03-29-11, 06:21 AM
Actually, Fred, that would be a demodulator. The cable box may already have A/V outputs. If the Bravia doesn't need the cable box it could be used to feed the other TV from its A/V outputs.
Old 03-29-11, 06:36 AM
fewalt's Avatar
It doesn't look like the OP has a cable box. If he had a cable box he wouldn't be using two coax connections on his bravia. (or CERTAINLY shouldn't be)
fred
ahhhh, afterthought: couldn't the OP use a splitter in reverse, let his tv scan for channels?
Old 03-30-11, 06:37 AM
A splitter can work as a combiner, however over-the-air and cable channels share the same frequencies. Here's a frequency chart.
Two channels on the same frequency will cause all kinds of issues.
Old 03-30-11, 11:08 AM
fewalt's Avatar
Well then:
simple A/B switch:
Dynex Coaxial Cable A/B Switch DX-AD112
fred
