fixing vhs tape
I knocked a vhs tape belonging to my son off a shelf. of course this is the only damaged one out of the several that fell.it is a $30 pay-per-view wrestling event which is no longer available.the outside case cracked and the tape inside tore.is there any way to fix this? i hate to throw it away if it can be fixed at all. any help would be appreciated. thank you
Safest thing available to prevent undue wear on the video heads and problems with the machine is to TRASH the tape.
Get on with your life, save your machine, and forget about it. The wrestling community will come up with something even better next week for you to record.
Smokey
Smokey
Smokey
Smokey
i thank you for your responses. obviously throwing the tape away would be the first option one would consider. however the tape is my sons and $30 does not come easily for a youth. that is why i asked if there were any other options to consider. i really did not need a flippant response when i was asking for help and that is what this website is for is it not? once again my son and i thank you for your quick and helpful responses.
