DVR Service - Cogeco
Yesterday turned on HDTV and got "DVR Service is Unavailable" and no signal. Called Cogeco. They reset the cable box and everything worked except the "List" function which allows you to view saved programs. Called again. They said they'd send a stronger signal but if that didn't work, the DVR was kaput. It didn't. Seems to me there must be some reason for only one function to be bad or maybe there are others I just haven't found. In any case, has anyone else had this problem and could you fix it?
The DVR units are basically a small computer. I'd venture to guess this is a glitch in the software and may be able to be solved with a reboot. If not, I'd replace the DVR.
