out door speakers
Old 03-31-13, 06:15 PM
out door speakers
I'm installing speakers around my in the ground pool. I want to run speaker wire from the house. I plan on using 1/2" PVC pipe, how deep do I have to trench the conduit? What size wire would be best (about 100' total)?
Old 03-31-13, 07:40 PM
Received 508 Votes on 478 Posts
Normally when running PVC for electric you would keep it at 18." That would be my recommendation in this application.
I would also use either #16 or #14 speaker wire. Probably lean towards #14.
Conduit carrying Class 2 wiring does not have any depth requirements, but the 18" required for standard electrical is a safe bet simply to avoid hitting it in the future if you need to run a tiller or something over the area. Assuming you will be using "Rock" speakers and a 100w receiver, you should be ok with 14ga wire over that distance. If you want to leave room for more power later on, use 12ga.
