Sony tv - kvxr29m50
Old 10-18-13, 07:37 AM
Sony tv - kvxr29m50
Hi,
This is my 1st post & appreciate enrolling me into this forum.
My TV suddenly won't start. When I press the ON sw, it just makes a click and even the ON light won't come.
What could be the issue/ Is it just a fuse?
gds
kapila
Old 10-18-13, 09:08 AM
Received 517 Votes on 487 Posts
Welcome to the forums from Sri Lanka.
That's an older 29" tube style TV.... correct ?
If you hear a clicking when you push the power button then it's a power supply failure. Unfortunately it's not a DIY repair unless you are familiar with electronics servicing.
Old 10-18-13, 09:53 PM
Yes, it 's older Sony Wega CRT model.
What are my options? goto the dealer?
rgds
Old 10-18-13, 10:07 PM
At the very least you would need a schematic/service manual to work on the set. The service manual should be available for purchase online but then you would need a VOM test meter to check parts.
So your best option might be to take it to a repair center. I'm not sure on the price of electronic equipment there but make sure the cost to repair doesn't exceed the cost to purchase a new LED/LCD TV. I'm sure the repair center can advise you.
Old 10-19-13, 08:15 AM
Well, I've already downloaded a service manual. But electronics is not my turf.
As suggested i'll try a TV repair centre & see.
regds
Old 10-19-13, 08:48 AM
I'll bet the service manual looks more confusing to you then a road map.
I was checking into it further. There are a series of steps you could follow but they do require a meter.
At least see what the repair centre says and go from there.
