hitachi l32hk04u- bottom 2/3 screen is black. help!
Old 12-19-13, 01:39 PM
Hi all,
newbie here please be gentle lol.
I have a hitachi l32hk04u hd lcd tv.
been a brilliant tv, untill while watching a dvd the bottom 3rd of the screen whent green. Could still see through it though.
a few weeks later it increased to 2/3 of the screen.
then instead of jus looking filtered, it is now just completley black. Can just see the top 3rd. Sound and functions still work fine, just the black screen.
Help would be greatly appreciated!!
Old 12-20-13, 09:34 PM
Justin Smith's Avatar
Did you try a different HDMI cable?
Old 12-20-13, 09:57 PM
Received 1,045 Votes on 969 Posts
Welcome to the forums.
I'm guessing you're from the UK as I can't find any service info in my regular channels nor do I recognize the chassis.
Are you going to open the unit and try repairing it ?
Did the dead area creep up slowly or was it just larger one day?
Was the line between the picture and the dead area jittery ? By that I mean is was that line constant or was fluctuating up and down.
It could be as simple as a connector between the LCD display and the driver board need a reseating or it will need the driver board replaced.
Old 12-23-13, 01:03 AM
Hi guys, thankyou for your replies.
it appeared when using scart lead, but is there eve n when nothjng is plugged in, so is deffo the tv.
yes im in the uk lol, I have taken the back off and inspected however not knowing how a tv works I could little else but check the soldering lol. Whats a driver board :s haha
Old 12-23-13, 06:10 PM
In the picture below is the display driver board. You could try removing the metal cover and reseating all the connectors on that board...... carefully and with unit unplugged.
Old 12-25-13, 01:31 PM
I shall try that, any other ideas ? So im not takinv back off and on all day haha
Old 12-25-13, 03:17 PM
If it's not an intermittent connection then it's a defective board at which time you'll have to decide if you want to try locating a board or replacing the TV.
Leave the bakc off for now. It's not hurting anything.
