Doing My "Do Diligence" Research
Old 02-08-14, 10:18 AM
C
Good Day All,
I am researching apple compatible stereo receivers and it has come down to the Pioneer VSX-822-K.
VSX-822-K - 5.1-Channel 3D Ready A/V Receiver | Pioneer Electronics USA
My problem is I don't have a good understanding of Ethernet. Can I connect wireless or do I need to run a cable?
With AirPlay, stream music from iTunes to the VSX-822-K and play it through your home theater system without docks or cables. Simply connect the receiver to your home network via Ethernet, and it instantly becomes the hub for playback of your iTunes music from your connected Apple device or networked computer.
Down the road I would like to connect it to the Apple Time Capsule external storage. This is where I will keep my music, etc
Thanks in advance.
Old 02-08-14, 10:27 AM
Received 2,677 Votes on 2,429 Posts
Nice receiver
In looking at the specs. you are required to run a network connection to the receiver.
Old 02-08-14, 10:31 AM
C
Thanks
Ok Thanks.
Do you have a suggestion on the cable type?
Old 02-08-14, 10:35 AM
CAT-5E would be fine. You could also use CAT-6 for future higher speed applications.
