Optoma ES520 lamp problem
Dear All,
We are a group of VolunTeachers and 2 or 3 times a week do VolunTeaching
in a nearby village.We have above subject projector as on today not working.I wish to know whether its lamp be tested/checked outside of projector? or
how to check the availability of power at the socket of the lamp?
Thanks in advance.
Jitu
Thanks in advance.
Jitu
Welcome to the forums.
That projector uses a metal halide mercury vapor type discharge lamp. It cannot be checked for operation other than checking to make sure the interior capsule isn't broken. Since it's a discharge type lamp the voltage is too high to measure. The only way to diagnose a problem is to replace old lamp with new.
If you look at the manual I left below.... it tells you how to read the diagnostic LED's built into the projector for the lamp.
Projector-manuals Optoma_ES520.pdf
