2 HDTVs, both with NTSC, one not showing digital channels.. ?
Received 0 Votes
Both TVs are hooked up to basic cable television.
First TV is "UN46B6000 46" 1080p LED HDTV (2009 MODEL)." This one finds digital channels during scanning, which are displayed on channels with dashes (ie. 57-1).
Second TV is "RCA 32'' Class 720p 60Hz LED HDTV - LED32B30RQ (2014)." This TV will not find the digital channels. I've tried all I know to try.
Does anyone know what may be keeping the newer (yet cheaper) TV from showing the same channels when hooked up to the same cable line?
What input are you using? Is digital decoding available to all inputs on your TV? Your TV may require a digital decoder box to convert the signal when feeding it to an RCA or RF/coax connection.
Hmmm...what does your DTV signal strength look like? Can you manually tune to a digital channel using a number from the other TV that you know should work?
EDIT: One other question....is this the exact same line that the other TV was connected to? Or is it split off somewhere? Just wondering, not sure, but maybe a splitter could affect the upper channels? I don't think so, but it could be possible. On second thought...I don't think so after reading up. It's not like VHF and UHF.
Received 0 Votes
On that channel menu, it isn't showing the DTV Signal on the 5th line at all. It doesn't even say "DTV Signal" on the line.
Edit - No, I can't select a digital channel by punching it in. It doesn't go to the channel.
Well, if this is the same exact line as the working TV, it seems either the TV or the programming/operation would have to be the issue. It might be a bit of work, but if it is not the exact same line, I'd swap them if possible and see the results.
Received 0 Votes
I moved the RCA and hooked it up to the cable from the Samsung. Ran the scan (cable) and the result is the same... 57 channels. I noticed in this manual it specifies to hook everything up before plugging the power in because it doesn't support QAM under cable channel search. Since I'm unsure if it was set up in that order initially, I tried resetting it as best I could. Reset to factory defaults, unplug while on and let it sit, etc. If there is a harder reset than that, I don't know about it.
Yes you are correct, it should. I have an old non-digital TV in my garage, and it gets all the channels in my basic package. On my other TVs, which all have digital turners as well, I get both analog and digital versions of channels that come in both flavors (ie: 7 and 7-1) and I can choose which one to use.
I'm thinking your digital tuner may be no good. Did you just buy this? Or did you get it used? Even on a new set it could be bad.
Yeah...RCA is pretty much...uh..bad stuff? I have Sony, Phillips, Hitachi, Samsung, and Vizio. The non-digital garage Sony is the oldest but has a great user interface and good picture and sound. The Vizio has great features and picture, but the menu is a pain in the tooshie. The other 3 are pretty much good and bad depending on what you want them for. A guest room TV doesn't need the best picture or sound, but the kitchen unit needs good sound to overcome fan and cooking noises.
Hopefully your new one picks up all the channels.
I kept suspecting that the TV did not support digital on it's coax input but I just downloaded the manual. It specifically says that the ant/cable coax input can receive analog and digital.
In the USA over the air analog was turned off in 2009 and I think most cable TV is transmitted in digital format. I'm wondering if your problem is with the cable box? Also, could you be looking at standard definition versus HD channels instead of analog versus digital?
I'm still not sure how the signals are transmitted, but I suspect in many places (like where I live), basic cable is transmitted in both analog AND digital for those channels that have HD programming. Since my old CRT non-digital garage TV pics up 72 channels SD and my digital TV's pick up those plus some (not all) of those same channels in HD with all the program info, I'm assuming thats how it works.
And no cable box required here. We have one for the LR big screen, but only because it's part of the cheaper rate package. I went to turn it in when they dropped the TV guide channel and they said it would up the package price by $10, so I kept it. When Suddenlink took over they added an onscreen guide, so glad I did.
#22
No, he's got NSTC (which is the old analog standard) and ASTC tuners. Every digital TV has both AFAIK. He's hooking up to the right thing since he was getting the basic 57 analog channels. Hope the new Samsung is working correctly.
