speaker push clamps
Old 07-25-14, 06:46 PM
D
speaker push clamps
some receivers have the cheap push spring clamp connectors for the speaker wire
... does anyone make a copper flat that fits into those and has a good connection and has a regular screw type attached to the other end for the wire..??
Old 07-25-14, 06:54 PM
P
Received 2,107 Upvotes on 1,886 Posts
I replaced the connectors on my old receiver. We got snowed in one weekend and I got bored and opened the case and soldered wires to where the crappy connectors used to connect. I used some female RC helicopter battery plugs and put the male ends on my speaker wires. There was nothing too special about the connectors other than it's what I had on hand at the time.
Old 07-26-14, 07:25 PM
D
did you notice a better sound??????
Old 07-27-14, 04:39 AM
R
Received 1 Upvote on 1 Post
Here's a link to the speaker terminals search results at Parts Express. I don't think the benefits, if any, outweigh the time & money to change out the spring-loaded terminals. As long as they are not corroded, making a solid connection and holding the wires tightly in place, a compression connection is as good as any.
Old 07-27-14, 01:08 PM
Received 3,884 Upvotes on 3,481 Posts
It sounds like you are looking for a terminal to use on the ends of your speaker wiring. You can use crimp or solder on pins.
Gold Plated Speaker Pin Plugs, Monopric
Crimp style speaker wire cable tip plug connector
Old 07-27-14, 05:32 PM
P
No, there was no improvement in sound. I replaced the connectors because the ones on the receiver were very "tender". I had to be very careful when inserting the speaker wires and clamping the connector closed. Often sliding the receiver back into the cabinet was enough to knock the wires loose. So, out with the factory connectors.
Old 07-27-14, 07:16 PM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
You could also solder the wires.
