2 channel speaker switch
Old 08-28-14, 06:54 PM
Anyone know of a speaker selector box,2 pair is ok, that costs under 12 bucks???
Does Walmart have a cheap one??
Old 08-28-14, 07:06 PM
Received 381 Votes on 358 Posts
Would you trust a cheap switch on your receiver ?
I doubt walmart even has speaker switches. You'd probably be better off checking at radio shack.
Old 08-29-14, 09:43 AM
I have a 15 watt per channel Sony tuner with 6 inch speakers. And I have a set of 5 watt mini 3 inch RCA speakers in another room. Given the small watt draw could I just bundle them together
and cram them onto 1 set of spring clips??
Old 08-29-14, 08:50 PM
Received 2 Votes on 2 Posts
The speaker wattage is the power they can handle before you blow them - not the amount of power they draw.
If you add the speakers as you mention, you change the ohms. If your tuner is made for 8 ohms, and you parallel two speakers, the tuner will see only 4 ohms.
If you wire them in series, the tuner will see 16 ohms. It may work either way but is not optimal.
Any double pole, double throw switch will do what you want. This is not house wiring or a commercial sound set up.
Old 08-30-14, 05:18 AM
Old 08-30-14, 07:26 PM
thanks that looks pretty good.
