HITACCHI 57F510 TV problem
Old 10-21-14, 12:29 PM
I have a HITACCHI 57F510 TV and the picture is starting to break up. I am suspecting that the lamp is the problem as it is 10 years old. Can you tell me if it is possible for a non tech person like me to replace the lamp. I see a lot of screws holding the back cover together which shouldn't be a problem but not sure what I will be up against when I get it off.
Thanks for your help.
MJ
Old 10-22-14, 01:06 AM
Received 510 Votes on 480 Posts
Welcome to the forums.
That Hitachi TV is a CRT (cathode ray tube) type unit. No replaceable lamp. If you had a tube problem..... only a single color would be affected. Your problem may be intermittent board connectors or a driver board failure.
Have you tried different inputs into the TV ?
