TV Wall Mount - Another One
Old 10-28-14, 11:46 AM
dpat09's Avatar
Hi! I am new to this forum and an amateur diyer. I am planning to wall mount a TV in my master bedroom. The wall that I plan to mount the TV on is shared between the MBR and the bathroom. When using the stud finder to locate stud, it shows that there is a live wire behind the wall. The issue is that the ac detection light goes on for the entire wall which is about 48 inch wide. I am not sure if the stud finder has some issue. Could it be that Stud Finder could be sending out faulty signals. Any suggestions or way around it?
Old 10-28-14, 12:54 PM
Seems to me that the sensitivity is set too high for finding electrical wiring. If you have a detector that is not adjustable, I would suggest getting a different model.
Old 10-28-14, 01:08 PM
dpat09's Avatar
Thanks Mile. I do not have an adjustable one. Will try another one as you suggested.
Old 10-28-14, 01:32 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Before buying another detector what electrical is on the other side of the wall. Not sure what the problem is. Having a cable in the wall doesn't mean you can't mount the TV. You just have to be careful.
Old 10-29-14, 01:23 PM
dpat09's Avatar
Thanks. I got another stud finder and it worked perfectly fine. Almost ready for the installation
Old 10-29-14, 03:12 PM
Great news! Hopefully things go smooth from here on out.
