3 year old 27" GE TV is DEAD!!
Old 03-22-01, 09:53 AM
Guest
My TV is 3 years old. It has never been jarred, droped, or hit. It just quit working. When I try to turn it on nothing happens, no noise, lights etc. I removed the back and checked the fuse and it's good. I'm at a loss. HELP!
Old 03-23-01, 09:31 AM
D
1st thing I would like you to do is unplug the tv for 5 minutes , then plug it back in. Not likely will change anything just don't want to overlook anything that is just hungup.
I assume that it won't turn on from either any remote or from the tv itself. Or even give a clicking sound when you attempt to turn it on.
http://forum.doityourself.com/showth...threadid=54036
look at the info that I haev posted on about thread, the site I included in that thread is an excllent source of basic information on tv's.
Your problem appears to a low voltage power supply in origin , look at the info in the otherthread I mentioned, I don't think this would be an expensive repair, but like anything else labor is always the larger cost than parts, I always usually recommend if the repairs approach 50 % of teh cost of replacing the set than that is usually teh route I recommend.
