Vizio TV: loose F connector
Old 02-23-15, 05:22 PM
T
the dtv connector has come loose on my vizio tv, and I would like to know:
about how much would it cost to fix it
what part do I need to buy(Do I need to replace the board or can the connector be replaced with minimal effort)
where would I get such a part
the model number for my tv is E421VA
thanks in advance
Old 02-24-15, 04:04 AM
R
Received 1 Vote on 1 Post
I haven't worked on a Vizio but other loose RF connectors I've fixed just had to be re-soldered to the board.
Old 02-24-15, 10:21 AM
Received 1,044 Votes on 968 Posts
DTV connector ? Is that the HDMI connector you are referring to ?
Old 02-24-15, 12:02 PM
T
I am referring to the coaxial connector. and I don't have any soldering skills, but it looks like removing a few screws and some wires would allow the entire board Name:  IMG_0581.jpg
to come off and be replaced.
Old 02-24-15, 04:56 PM
If you were extremely handy you could fix it. It would require removing the top of the tuner box where the connector is located. The connector is held thru the metal box with a crimp. You may be able to see where the center pin of the connector solder to the board. There is a 50-50 chance it's on the top of that board.
You may be able to find a local TV repair place where they could fix that connector for you. I used to fix them all the time.
In case you can't fix it. The part number for that board is CBPFTQACB5K047. Be advised that some boards are sold with a dud return option so be careful not to destroy the board if you attempt to fix it. There are certain variations of that number you'll see on the board.
You can search online for the board by the part number.
You can also try TV Parts, Universal TV Stands, DLP Chips | ShopJimmy who always has fair prices and is extremely knowledgeable
Old 02-24-15, 05:31 PM
T
thank you for all that!
Old 02-24-15, 05:55 PM
T
is it even worth fixing sense it is not even 5 years old?
how long do 500$ tv's last these days?
Is vizio a good brand?
Old 02-24-15, 05:59 PM
I'd say fix it. That board should be under $100.
Old 02-24-15, 06:27 PM
T
it is I was just wondering if tv's that are about 500$ start breaking after 4-5 years?
Old 03-10-15, 07:58 PM
Piddler's Avatar
I'm not sure how long the flat screen tv should last but my guess is a lot longer than the CRTs of old because there is not heat involved or high voltage. My guess is if nothing goes wrong in the manufacturing process, these things will last 10 to 15 years and you will probably replace it for a better functioning unit with more options before it goes bad. So, if you like the tv, have it fixed.
