DIY OTA antenna
Old 03-17-15, 10:33 PM
D
DIY OTA antenna
Im thinking of building my own antenna. I can't find this answer, could I split the signal for 2 or 3 TV's. Also, what's more ideal, 8, 9.5, or 10 inch whiskers. I'm about 8-10 miles from the transmitters.
Old 03-18-15, 12:00 AM
Received 3,485 Upvotes on 3,128 Posts
Interesting question. There's another thread running on homebrew antennas.
http://www.doityourself.com/forum/ho...tters-nyc.html
Old 03-18-15, 04:25 AM
R
Received 1 Upvote on 1 Post
I cut mine to 7 inches. You can split the signal. If the TVs lose reception you can add an amplifier.
Old 03-20-15, 04:50 PM
A
Received 256 Upvotes on 235 Posts
The best length of the whiskers depends on the actual channel(s) you will be receiving, not the distance to the transmitter(s).
The actual channel number is usually not the same as the number in the station's logo.
I do not have handy a table or list ot calculations needed to determine the length for the whiskers.
Old 03-21-15, 04:27 AM
R
7 inches is the longest 1/4-wave you'll need for UHF.
Old 03-22-15, 08:52 PM
D
Well, my DIY version seems to match the performance of my RCA ANT751. The DIY is slightly stronger, BUT, thr RCA is in the attic and is split.
