Older Magnavox TV/stereo console
Old 06-06-15, 02:33 AM
G
I have an older Magnavox console which does not respond to the remote power button or the power button on the tv itself. In the past after a power blink I have had to unplug the tv for a while and then plug it back in before I could turn it on.
on. I have checked the chassis fuse and it is not blown. The Model# is 32T522 AK02
The Serial#14375150. It was manufactured in Feb 1999. It has had a beautiful picture and is a stereo model. I don't want to write it off if I can possibly repair it.
Old 06-06-15, 10:15 AM
P
Could you grab another remote off ebay $10-15 and see if that helps?
Old 06-06-15, 11:27 AM
Received 1,051 Votes on 975 Posts
Welcome to the forums.
If the front panel switch doesn't work then another remote won't help.
The model number would have no spaces in it but I still can't find the model number you posted. Please double check it for me and if there is a chassis number posted I could use that instead.
Old 06-07-15, 06:00 AM
G
The only other number I see is 3419U091D. I think it is the power on relay because I no longer hear it click on or off.
Old 06-07-15, 09:11 AM
You're saying the model number is posted correctly ?
No go with the second number.
It's not the relay..... it's what turns the relay on.
Old 06-07-15, 10:07 AM
G
If the push button on the TV and the remote don't activate it what's between those and the relay?
I double checked the Model# its correct or at least that's what's printed on the back of the TV.
If it will help I can take a cell phone pick and send it.
Old 06-07-15, 10:20 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Old 06-07-15, 12:05 PM
G
Size:  16.5 KB Here's a picture and a number I found on the chassis board.
EMZ567A001
Old 06-08-15, 06:13 PM
G
Thanks for your help. I've decided to junk it and get a new 4k Samsung.
Old 06-08-15, 06:36 PM
I did actually find a Phillips link to that model number but no service manual is available.
Therefore I couldn't give you much help.
A new TV....
