Sound variation when using on cable feed for TV
Received 0 Votes
When I am using the receiver/surround system to view TV via cable feed the sound variation (volume and quality) from channel to channel is horrible. If I separate
TV and use straight cable feed ad sound bar, sound levels are acceptable.
Any ideas on what to do?
Fact is, TV audio does vary between channels. It also varies between programs and commercials on the same channel. You may not be hearing it as pronounced on the sound bar (perhaps it has a "leveler"?). If the receiver has a compressor or other processor to even the sound, try activating it.
