Samsung 42AV500U stand screw size
Received 0 Votes
Hi everyone, I own a Samsung 42AV500U LCD TV and I recently moved out from my apartment where I had it wall mounted. The thing is that I can't find the screws for its stand and they're not the same as the screws for the wall mount brackets. Does anyone have any idea what the dimensions of the 6 screws might be?
Thanks a lot!
Thanks a lot!
I can't locate that model number in the Samsung database. It looks like all Samsung TV model numbers start with letters.
I did locate that model number in the Toshiba database.
Can you check and confirm your info for me ?
No problem. That TV stand uses M5x0.8 screws. Part # 75012411
encompass parts/Toshiba/75012411/Stand_Screw_With_2Washer,_Stand,_M5x0.8
You should be able to find these screws at HD. Here locally and probably everywhere, the screws are not displayed with the other screws, they're in Vidmar drawers with other metric and specialty fasteners.
Received 0 Votes
Thank you PJmax for following up and Handyone for your info. You guys were a big help! I really appreciate it, I wasn't able to find the size of the screw anywhere and I have pretty good Google skills.
Cheers!
Cheers!
