Sharp Notevision Projector
Old 08-13-16, 02:41 PM
E
I'm trying to figure out how to connect my projector so that I can view cable TV on the big screen. Thanks
Old 08-13-16, 02:49 PM
Received 2,965 Votes on 2,675 Posts
Can you post a model number ?
Old 08-13-16, 03:54 PM
E
It is a sharp PG B10S. Thanks
Old 08-13-16, 08:53 PM
C
http://www.projectorcentral.com/pdf/...anual_2176.pdf Go to page 50 - 54 to find out hook up options.
Old 08-13-16, 10:04 PM
Looks like you're going to need to buy a Sharp AN-C3CP component connection cable.
This cable has an HD-15 mini D connector that plugs into the back of the projector and three RCA plugs (red-blue-green) that plug into the component output of your cable box. This will be a video only connection. Audio would require a second cable.
You can also use an S-video cable but not all cable boxes have that output jack. This would be a less costly option but not the best available video picture. This method is also "video only".
Old 08-14-16, 02:29 PM
E
Ok I think I still have that cable. However, my cable box connections are already full. Is there such a thing as a rca splitter. Thanks
Old 08-15-16, 10:53 AM
Most cable boxes offer several output connections. If you look on the back you should see three jacks... red, green, blue. Are they used too ?
You cannot split component video with generic Y cables or splitters.
There may be a powered component video splitter.... I'd have to check.
Old 08-21-16, 11:09 AM
E
I have a VMS1100 multi DVR cable box. And there are only a few openings in the back for connection.
Old 08-21-16, 05:05 PM
E
I connected the AN-C3CP to the cable. However, no picture came thru.
Old 08-21-16, 08:02 PM
You need to go into the Sharp setup and select the component input.
Did you use the RGB component output lines on the box?
Old 08-22-16, 08:54 AM
E
I connected the Sharp AN-C3CP component connection cable in the back of the projector. I had to also purchase a "3-rca rgb rg-59/u component video splitter". I did this because the red,green, blue outlet was already occupied.
I switch the projector to input 1, which is what the Sharp AN-C3CP component connection cable is connected to.
Thanks
Old 08-22-16, 09:33 AM
Input 1 contains the RGB signal but may not be recognized automatically. You may have to go into input 1 settings and change from AUTO to RGB.
Also try the connection to the cable box without the adapter.
