Broadcasting cable signal to basement projector
Old 01-29-17, 06:59 AM
Marq1's Avatar
Received 95 Votes on 86 Posts
So I did not make provisions for cable hookup in our basement theater and trying to run a new cable would not be easy,
Our projector is hooked up to DVD player through a AV receiver.
One of these type of devices will get the signal to another TV but have not been able to confirm if connecting to my AV receiver will work correctly.
https://www.amazon.com/Nyrius-Transm..._cd_al_qh_dp_t
Old 01-29-17, 07:30 AM
You won't know until you test it. Make sure that there is a good return policy on the device before you buy it.
Old 01-29-17, 08:03 AM
Received 343 Votes on 321 Posts
What cable did you use for this connection ?
Or are you trying to stream from a cable box upstairs to the A/V receiver downstairs ?
Old 01-29-17, 02:25 PM
Marq1's Avatar
Correct.
Everything in the basement is HDMI.
I'll give the company a call this week to confirm!
Old 01-30-17, 02:15 AM
Received 120 Votes on 107 Posts
Back when I had satellite [single receiver] I used a similar product to get the signal to my bed rm TV and it worked well. It did require the satellite box to be on and if both TVs were on they got the same channel.
