Need help finding rotary switch for Entertainment Unit please
Old 04-26-18, 10:50 AM
I need to find a replacement switch for this unit, I bought this unit about 10 years ago from JCPenneys. I’ve searched this forum but not finding a like switch answer.
can someone help?
Old 04-26-18, 10:55 AM
XSleeper's Avatar
Received 195 Votes on 181 Posts
It would help to know what your "unit" is.
Old 04-26-18, 11:08 AM
I have no idea what a style or model number is
How do I post pics here?
I have no idea on style or model numbers.Have the switch out
Old 04-26-18, 11:10 AM
Received 199 Votes on 184 Posts
Here are instructions on how to attach pictures: https://www.doityourself.com/forum/e...-pictures.html
You can also tell us the brand, make and model numbers.
Old 04-26-18, 11:12 AM
Shadeladie's Avatar
Super Moderator
Received 40 Votes on 32 Posts
We just had an upgrade done, so that attachment icon will be in a different place than the pic shows.
Old 04-26-18, 11:26 AM
Pictures of switch
Pictures of the switch are attached .....I think
Old 04-26-18, 04:04 PM
Received 345 Votes on 323 Posts
That is a self contained dimmer board.
I'm guessing for some kind of lights in an entertainment center ?
I'm 99.9% sure you won't find a replacement for it.
It could be repaired if that's where the problem is.
What is the problem you are having ?
Old 04-27-18, 09:07 AM
Light switch for dimmable lights in entertainment unit
Thanks for the response. It's been awhile but I think it stopped clicking to off position, became hard to turn then stopped turning lights on.
I hope this sounds fixable,
Old 04-27-18, 09:22 AM
There should be two wires on that board. I guess you cut them off ??
You can connect those two wires and the lights should work.
See if there is a number on the brass part of the control. It may look like 50k or 10k, etc.
Old 04-27-18, 10:03 AM
He probably did cut the wires to get it out. I'll get someone else to see if they can see a number.
Thanks PJmax, I'll get back to you later
