Sony TV screen sizing problems
Model: XRB-65X850E
When viewing the TV using the Amazon Stick, the picture is too large and shifted to the right. The results are sometimes the actors heads are cut off (top) as well as anything to the right of the screen.
Normal cable watching is ok
I recently downloaded area-51 utilizing the Stick and the same problem occurs. It happens on Netflix too using the stick.
Please help if you can
Thanks
Thanks
There should be settings for screen size using the remote under menu. The picture may need to be formatted to the screen using various/different sources.
Did you try changing size by pushing the WIDE button on the bottom row of the remote control ?
