Powered Subwoofer Connection
Old 03-13-19, 11:44 AM
Hello,
I am trying to. make sure I have my Powered Subwoofer connected right. I have an Onkyo TX-SR604. receiver and an Infinity HTS-SUB10 Powered Subwoofer. The receiver has only one RCA jack marked "Pre-Out" and the Subwoofer has two RCA jacks marked "Low Level In' with L & R. I used a Y - RCA cable and connected the single end to the Receiver and the double end
two the two Subwoofer connectors. Is this correct?
Name:  Screen Shot 2019-03-13 at 2.29.06 PM.jpg
Name:  Screen Shot 2019-03-13 at 2.28.13 PM.jpg
Old 03-13-19, 01:47 PM
Upvotes Received: 213
Typically you would connect the single preamp line to the left channel. The sub will sum the two inputs together. I don't think you need to use a Y cable but it won't hurt anything if you do.
Old 03-13-19, 02:34 PM
Upvotes Received: 141
After you get it hooked up don't forget to go into your receiver and setup the crossover frequency for your sub.
