Can a/v cable be used instead of component cable?
Old 03-16-19, 04:50 PM
K
Received 1 Upvote on 1 Post
I have an A/V cable for my DVD player but tv only has jacks for a component cable. Can A/V cable be used anyway? If so which jack gets the yellow cable?
Bet I just have to get a component cable but thought I would ask.
Thanks
Old 03-16-19, 05:38 PM
Received 75 Upvotes on 70 Posts
Yes you can provided the cable is of decent quality. It does not matter which gets the yellow one provided each color gets connected properly to the respective color jack.
What are you using for the audio though? If you are using the TV speakers you will need another cable with two additional RCA jacks for the Red/White audio signals
Old 03-16-19, 06:47 PM
A
Received 256 Upvotes on 235 Posts
Put the yellow plug in the green jack, the red plug in the red jack, and the white plug in the blue jack.
This is not absolutely positively guaranteed but this has the best chance of working.
In component video the luminance or Y (green) has higher frequencies than the (not exactly) red or Pr and (not exactly) blue or Pb components. The cable assembly may or may not have equal quality for all three internal cables.
