Samsung LED TV Screen (Need HELP)
Received 0 Votes
Hi guys brought this TV as a faulty set which was unable to turn ON, after replacing the power board TV was able to turn on but there is a problem with the display, Please advice.
Colour Settings : WARM
Colour Settings : COOL
Welcome to the forums.
A model number would be very helpful.
Have you tried connecting an input to see if you get a picture ?
From what I've been reading...... it's a bad bond between the LCD and the ribbon cable. Other technical sites explain taking apart the actual LCD screen and cleaning the internal layers.
If it's an intermittent ribbon connection..... the TV may go normal when the screen is squeezed or tapped on. I have seen people whack the screen and it comes back. I little iffy for me.
