Tv antenna
Old 09-25-19, 11:37 AM
Tv antenna
I recently returned 12 cable boxes and bought an antenna. I bought a 12 way splitter and connected all thge cables to the antenna and i have no signal. S it possible the splitter is defective or did i do something wrong?
Old 09-25-19, 11:40 AM
XSleeper's Avatar
Received 195 Votes on 181 Posts
Splitters reduce signal, so a 12 way? yeah, that's your problem.
Old 09-25-19, 11:59 AM
Received 344 Votes on 322 Posts
Welcome to the forums.
Are you even sure if there are signals in your area ?
You need to connect the antenna to a single TV first.
Do a DTV off air search and see what it comes up with.
This will be a baseline so that you know what's available.
Old 10-03-19, 05:28 PM
I've been using an outside passive antenna for several years (no amplifier). I receive around 40 channels, 3 TVs. No trouble with that setup until 1 channel recently changed something due to some channel re-allocation.
Did you do a search of new channels on your TVs in antenna mode? As stated previously though - 12 connections is a lot.
