TV volume control is too loud on lowest setting.
Old 03-25-20, 08:30 PM
D
Can anyone help fix this i can not find the manual for this tv online
polaroid tv ssdv3211-i1
Old 03-25-20, 08:53 PM
XSleeper's Avatar
Received 1,533 Votes on 1,377 Posts
So is this a problem with your remote or with your tv? If you have controls that are actually on the tv, try using the manual controls instead of the remote.
Old 03-26-20, 04:08 AM
Norm201's Avatar
Received 594 Votes on 531 Posts
Old 03-26-20, 05:00 AM
C
Received 20 Votes on 17 Posts
This happened to me recently, too. Not sure if this applies to you, but here's what i did. My cable provider's remote controls allow us to "synch" the remote to the tv, preventing the need for 2 remotes (1 tv, 1 cable box). When the tv volume jacked itself to maximum not even the physical buttons on the tv could lower the volume. I re-sync'ed the cable remote to the tv, and that solved the problem.
Dave
Old 03-27-20, 06:44 PM
D
Unfortunately it isnt a remote issue.... at volume 4 the tv is still super loud but at volume 3 its so quite i cant hear a thing
the tv isnt connected to any cable box i jus use an antenna so i only get the basic channels... or even wen i connect it to my xbox with a hdmi i still have the sane issue
i culdnt had anything helpful in that manual thanks thoe
anyone got any ideas
Old 03-27-20, 07:32 PM
XSleeper's Avatar
Have you tried anything outside the box, like maybe trying to plug in a set of old computer speakers or maybe a sound bar? They would have their own volume control that you could adjust.
Old 03-28-20, 07:17 AM
H
Received 250 Votes on 216 Posts
Look at page 20 of the manual above -
Most likely it's a combination of AVL + Sound-Mode
AVL "Automatic Volume Level" which makes quiet sounds loud, and loud sounds quiet.
Sound-Mode determines how much "spread" the sound has.
When you get an odd combination, you get too quiet for quiet, and too loud for loud.
Worst case, try a "factory resest" from the remote.
You MIGHT also check for a firmware update for the TV
Usually, that
