Can I use low voltage landscape wire as speaker wire?
I was given about 500' of old low voltage landscape wire. It is marked 14/2 low voltage use only I don't see any reason (other then being difficult to use because of the thick insulation) I can't use it for speaker wire but I just thought to ask first. I don't intend to make one 500' cable I am going to cut it up for various uses which should last me quite awhile.
I would use it. Electrons don't care whether "landscape lighting" or "speaker wire" is printed on the box. Speaker wire may have finer strands and be more flexible but #14 wire is #14 wire for this application.
OK that is what I figured. I do not intend to use it in the wall anyway. Yes the individual strands are pretty thick but as you said copper is copper (at least this wire is actually copper as I have seen CCA Copper Clad Aluminum or CCS Copper Clad Steel that is cheaper but obviously not as good as pure copper wire).
Oh wow that much! I don't know how much 500' of wire actually weighs (once stripped of insulation but as it is now it is a hefty piece of wire)
I have a friend who collects metal things for scraping (he is not one of those desperate scrapper types though. I remember when I used to live in the bad city area of town anytime a CRT television was tossed it was ransacked within 30 minutes for the copper in the back of the set). My plan is to use some for my various speakers I have around my house and give the rest to that friend he can strip the insulation off that is too much work for me
