Visio vbr120 Blu Ray player not playing blu rays.
It plays DVD's though. These blu rays play elsewhere fine. I didn't find anything in the settings to fix it. What's the usual cause? Can it be something physical? Are the physical components that read DVD's and blu rays different?
Does it show it as playing on the display screen. IE: elapsed time is running but no picture ?
Do you hear the disc spinning at startup ?
Is it connected to the internet ?
If not..... verify BD Live is turned off.
- BD Live is a feature found on most Blu-ray discs which connects to the internet in order to provide content such as the latest trailers. In many cases the disc may wait to load until the online content has finished downloading, so if the Blu-ray player has an internet connection but cannot access the film studio's server or the network speed is slow, the disc may take longer to play.
To rule out BD Live as the cause, navigate to Settings > Network > BD Live, and set to Prohibit. This will prevent discs from accessing the internet. On older players, you may have to press Menu > Setup > Network Setup > BD Live.
looking through the manual:
"Region codes
Blu-ray Discs and DVDs have region codes to help prevent
illegal distribution of discs. If the disc’s region code does
not match your player’s region code, the disc will not play.
The disc’s region code is displayed on the disc or disc
packaging. You can only play Blu-ray Discs that have a
region code of A and you can only play DVDs that have a
region code of 1 or ALL."
hmm...
"Region codes
hmm...
Blu-Ray took DVD to the next level. Technology had reached the limits of what could be done because of the wavelength of the laser light so they switched to the blue end of the spectrum who's wavelength is smaller. This allowed the dots & dashes (1's and zeros) to be smaller and each row of information to be closer together. This requires much greater precision above what a CD or DVD requires. Even the slightest mis-alignment of the laser, it's positioning mechanism can render it unable to read Blu-Ray disks.
juntjoo voted this post useful.
