hi,
I am restoring an early Revere S-16 and would appreciate receiving a copy of the amplifier schematic.
My amplifier has six tubes which according to the service manual is an "early model" and was not covered in the manual.
I am hoping someone on the forum has a copy of the six tube schematic they can scan and send it to me please.
Hello,
I just cut the cable and started using an HD Antenna. So I have a new LG
TV, DVD Player & Receiver. This hookup is new to me because using the HD antenna requires the signal to be sent from the TV to the Receiver. So my Receiver is Yamaha RX-V663, TV LG 55NANO75UQA and Samsung DVD Player. So I connected TV hdmi (ARC) to hdmi IN on receiver. DVD hdmi to TV hdmi (ARC). I also ran TV Optical OUT to Optical IN on receiver. But the TV automatically recognizes the Optical sound out. Shouldn’t the TV use the hdmi to send the sound to the receiver? Also, if I connect the DVD hdmi to the receiver hdmi IN, will the receiver play the DVD and TV signals simultaneously?
This is different for me because my original hookup was with a cable box and I ran everything to the receiver and the receiver to the TV but now with an HD antenna it’s all backwards.
Thanks for any help!
I have a Sport Sync radio Model SR-404 that is SUPPOSED to allow me to watch a football game and listen to it on radio. If I use a regular radio the sound is never in line with the TV. I do this because I want to listen to the home town broadcast because I really like listening to Merle Reese and Mike Quick. The sync radio was working fine until this year. The radio has positive (+) and negative (-) settings depending on which way I need to adjust the sound. However, I can no longer set it to the right setting because the negative adjustment doesn't work anymore. Does anyone know how I can fix that? The manufacturer, Scanner Master Corp., has a website (sportsyncradio.com) but when I go on there I go nowhere. They don't give a phone number and when I sent an email I got a message that it is a bad address. The 90-day limited warranty ran out about two years ago. The radio was made in China which I'm sure is a big problem.
Thank you, Rich
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/412x248/sr_404_1_8b7d8643de0526629e0dbb19a1b44aeb48f92ff1.jpg[/img]
