1996 RCA Big Screen
Our Big Screen projection television has a green hue to it when it is on. We have sattelite TV and use the s-video cable but it seems to be green on all inputs. Is there an adjustment that can be made regarding the blue and red or green lights that are in the back. Help. Thanks.
Pam
Pam
Good Afternoon, PamelaM:
Yes, the grey scale tracking is normally an internal adjustment on these sets but I don't recommend it for the novice. It involves changing some critical voltages on the projection tubes and has to be done correctly. If it is not done correctly, the life of the projection tube is in danger of being shortened substantially. And, unfortunately, we don't have the time and space for a crash course on this operation.
In any projection system of this type, green is the predominant color. A natural aging of the projection tubes will occur and both red & blue will taper off leaving green as the basic background color.
I recommend a call to the technician to perform a grey scale tracking set up on your unit. I should not be very expensive but it is wise to get some estimates.
Smokey
Smokey
Thanks Smokey,
We got quotes on repair shops to come out and take a look at the green hue in the TV. Most were not sure what the problem was. The company that finally came in took the front screen off and made adjust focus nad G2 controls, they also cleaned the lens and mirror. United TV Service in Chicago was here for about 20 minutes and charged 39 dollars. The screen looks like brand new. Thanks for your help.
Pam
Pam
